I have not found an easy way to plan a flight via routes with SD.
The only way I have found is to prepare the flight, in "Airways mode" and then amend the DCT between the WPT with the route names I have noted.
Would it be possible to, in case there is a route between 2 WPT to use the route identifier instead of DCT in the route when planning in "Airways Mode" ? I think this will make it much easier.
Thanks in advance.
