I am a long-term and a happy user of SkyDemon both for real-life as well as simulated flying.
This request relates to the sim flying.
In the past, I had no issues to connect P3D and X Plane to SkyDemon in order to learn and train all the SD features. Recently I acquired MSFS 2020 for which the connection to SD does not work out of the box (though there is a way via a 3rd party app; however I do not fancy an idea of buying the app and then using just a fraction of it).
Therefore: Would it be please possible to implement a feature that would allow SD to connect to MSFS 2020?
When googling yesterday, I actually found that one of your competitors (ForeFlight) is achieving this via a free 3rd party app called FlightEventsClient which is broadcasting the flight data on the wifi network. The above mentioned moving map software is then able to catch these data and use them as GPS input.
I tried the FlightEventsClient out. It connects to the MSFS 2020 and broadcast just fine, but the X Plane option in SD does not catch the broadcasted data.
Hopefully you will give this suggestion a thought. Thank you!
Regards,
Milan
