I have a question regarding flight-plan submission via Skydemon. I usually do not use SD for FPL sublission but I did for yesterday's flight.
When I called to check if all was OK, the briefing told be that all was ok must asked me if they could get my mobile number to add it to the flightplan. While SD has my mobile phone I understand that this is not submitted in the FPL ?
Is that correct ? Would it not make sense to make this info available so they can call you before starting a rescue mission if you forget to close your plan
