By Tim Dawson - 8/20/2020 10:03:04 AM
Hi George, the page warns you if you've stated the total time is 1:10 but you're logging 1:20. Perhaps we need to change the terminology we are using, because where we say Flight Duration we actually mean blocks time really. Does that make sense?
By GEAR - 8/20/2020 12:31:27 PM
+xHi George, the page warns you if you've stated the total time is 1:10 but you're logging 1:20. Perhaps we need to change the terminology we are using, because where we say Flight Duration we actually mean blocks time really. Does that make sense?
By GEAR - 8/20/2020 12:35:18 PM
Tim, I think I have discovered what the issue is. When I don’t log off blocks and on blocks times SD takes my take off and landing times and puts those in the total time box. When I log the off blocks and on blocks times then no warning messages are given.
By Tim Dawson - 8/21/2020 8:40:40 AM
Yes, quite. In the absence of blocks times SkyDemon autopopulates the flight times (because that's all we have) but you are of course expected to edit where necessary.
By GEAR - 8/19/2020 3:08:34 PM
I have been playing with the new logbook function in version 3.14.2. I think that it is a very useful addition to SD. I have tried to load some of my recent flights from the cloud, but I encounter an unusual message. For example if the flight duration is, say, 1:10 and I edit the Logged Time to, say, 1:20, I receive the message "The logged times you have entered are less than the flight duration. Are you sure this is correct?". I ignore the message and save the entry and all totals are fine.
