I would like there to be a default option for SD to show the Height above ground as part of the inflight displays.
There is the option to show Altitude, which I can then press to toggle to show Height, but every time I start SD from scratch I have to change the setting as the Height setting doesn't "stick".
I like to leave SD on Height and my Aircraft Altimeter on Altitude then I have both sets of information available to me, the designated flight height for when talking to ATC and the height above ground to be sure of ground clearance etc
Thanks, Geoffrey
