How often will you flying high enough above ground level that there will ever be a realistic choice of more than one or two airfields in gliding range to choose from?
If the engine stops, a quick glance at the glide range ring will show whether any are achievable. If it’s an urgent, but not an engine out or fire situation, pressing the orb is probably good enough.
