Dear fellow pilots,dear SkyDemon team,
first of all: this is my first post. Thanks to the (small) team from SkyDemon for building such a great piece of helpful software. It's incredible what you're building with such a small team. Keep it up!
I am flying in several flying clubs with a broad range of aircraft, luckily, all of them are equipped with AIR Connect, so I can stream traffic information to my iPad. However, since the Air Connect key is different per aircraft, I have to consistently go into the setup menu and manually change the Air Connect Key under the "Third-party devices" menu. Since I consider this to be a frequent issue, I'd like to suggest to make that configuration item somehow dependent from the selected / used aircraft in SkyDemon.
Would it be possible to add the AIR Connect key to the aircraft configuration, so it can be attached to a specific aircraft object in SkyDemon?
What would you guys think?
Cheers,
Patrick
