Two issues I am experiencing with the PC version of Skydemon when using Weight & Balance:
- Loss of all Loading Point data when creating a new route
Often I enter the loading point data first and then I start creating a route. Creating a route resets all loading point data. This is very annoying for airplanes with lots of loading points. Even hitting SAVE before creating the route does not help.
- Unreadable loading calculation with off-grid data
The W&B result chart only scales to the boundaries of the load lines (load limits). If the actual loading point is outside these lines, its position and the annotated takeoff weight is unreadable. Even if the actual loading point is inside the load lines, the max fuel point might not be visible.The diagram should always scale so all data is visible.
