Hi
Tomorrow and from Monday, 20.01.2020, The LS-R90 will be active due to the WEF. The LS-R90 Circle I can see on the Sky Demon map. But around Davos a Class D airspace GND-FL75 will be active. I can't find this on the map.
Thanks for having a look into it.
Best
Alain
Map of the SUP
SUP AIRAC SUP 001 2020
--Quote Start
The World Economic Forum will be held in Davos in January 2020.
The Federal Council has imposed restrictions on the use of the following airspace by civilian flights:
• Horizontal extent:
A radius of 25 NM around Davos (46°48'44" N / 009°50'59" E), above Swiss territory only (including the
Principality of Liechtenstein).
• Vertical extent:
From the ground up to FL 195.
2. Davos Control Zone (CTR)
Centre Davos 46°48'44" N / 009°50'59" E, Radius 2.7 NM.
• Vertical extent:
From the ground up to FL 75.
• Airspace class:
Delta
• Controlling unit:
Davos Tower 130.700 MHz.
Chart: see section 9 below.
3. Activation Times of LS-R90 and CTR Davos
• Friday 2020-01-17 from 1200 UTC until 1600 UTC
• Monday 2020-01-20 from 0700 UTC until Saturday 2020-01-25 1600 UTC (H24)
Note:
Changes to activation times may be announced via NOTAM, which may result in LS-R90 and CTR Davos having
different activation periods.
--Quote END
