Aerodrome designated points like DW412 (a point of an IFR transition of EDDW) are in the database of Skydemon. If I use if the "Find" tool of the iOS version and enter DW412 I will get the point and if I click on it a yellow marker occurs on the map at the requested position. The yellow marker disappears some seconds later - no way point to select left. But if I create a new route e.g. from EDLI to EDDW with DW412 in the route field I get an error: "DW412" is unknown.
On the other hand while flying (from EDLI to EDDW), I can select "DirectTo", "Find", "DW412" and now the way point will be inserted in my PLOG with the correct name and position and with a correct IFR way point marker in the map!
Why is it not possible the use these way points in planning mode?
Thanks Dirk
PS: The behavior of the PC version is nearly the same
