By vfr-uk - 8/26/2019 7:58:35 PM
Even just the info in title bars of the pack itself appended (callsign, start, end, date) would be much more useful than just debriefingpack.pdf
By vfr-uk - 9/1/2019 6:52:41 PM
It’s an issue if you don’t use folders for every flight - I certainly don’t. I mainly stay away from computers for SD use, so end up saving route to Dropbox or similar, and having to rename the file is just one more fiddle to do. Such an easy bit of code to change, and doubt would affect anyone else too much.
Embarrassingly I just found that the PLOG is actually stored -I just completely missed it within the text. I guess I expected it to be the same format as the one in flight with same column/details.
