Searching of R,P,D-airspaces - via search waypoint
http://forums.skydemon.aero/Topic29211.aspx
By jfw - 8/22/2019 8:48:48 AM
During a flight I was informed informed by the FIS of a zone that was active on my route. I had some difficulty to locate it on the map and was unable to search for it.
Since then I have been trying some searches and would propose some enhancements.
I have noted that some airspaces are searchable on Ident while some are not.
eg EBD26 is while EBLFA07 is not
I also noticed that the area is only showed in the search bow when the complete Ident is provided.
eg EBD lists"Debden" & "Hebden Bridge" only. EBD2 lists nothing and EBD26 lists the Danger Area....
I would suggest to make the IDENT searchable and also to list all the matching areas in order to facilitate the localization of some areas.
I also have noted that the TRA/TSA are can not be found....might be useful to integrate these as well....
Comments and view on this proposal are welcome....
