My log contains a lot of flights. That's okay and the log summary looks fine.
But, it contains also several simulator flights with XPlane from the winter saison.
Can you implement a method to exclude those flights?
My first thought was to suggest a fliter mechanism on the method where SD gets its position from..
On my iPad, I have 3 possible sources:
- Use location services
- Use FLARM with Airconnect.
- Use X-Plane
At least X-Plane comes under Simulators as an option, so it may be easy to mark flights where the position comes not from GPS but from WiFi as "invalid" for a log.
