+xThis is probably best solved by you revisiting the detailed set-up documentation for PilotAware, which includes how to set up SkyDemon, then asking again on the PilotAware forum if you continue to have a problem.
I suggest that you look at the Settings on your Ipad. Check that you are connected to the PilotAware WiFi.
In SkyDemon, Open the Setup Menu, and go to the Third Party Devices settings. Ensure that SkyDemon is checked.
