+x+x+xThey are connected. If many people express a desire to control the volume of these two sounds independently we will of course consider adding such functionality to SkyDemon.
Many thanks for the reply. Why is the volume of the voice much quieter than the warning sounds or is it just my setup? Perhaps the bias could be change slightly!?
I have the same problem - the warning tone is quite shrill and I can even hear it in the cockpit above the engine noise without piping it through the headphones; whereas the speech is a murmur in the background that I can only hear on engine-idle. Not able to plumb SD into my rented aircraft (no obvious input socket), I wondered if there was a way to increase the speech volume.
Best solution: Untick audio alerts. Tick voice alerts only. Then it works like a dream.
You will find that you don't need the audio alerts (which were meant to draw you attention to the screen to read what the problem might be) once you use the voice alerts. With those clear natural language voice alerts that SD provides you have all the information you need, and you can keep your eyes outside.
