By peter.kesten - 4/22/2019 11:55:58 AM
Hello everybody, dear Skydemon team, as far as I can tell, SkyDemon outputs maps on printers at a wrong scale. If I am in the settings e.g. 1: 500k specify, the 25km line in the printouts at the bottom left is always about 4.3 centimetres long, which corresponds approximately to the scale 1: 581k. This happens both in the "print-chart" function via the right mouse button and when printing briefing packs. I have tested this on several systems. SkyDemon plan on "real" PCs as well as in the wine-wrapped version on Macs, as well as the app on iOS devices (iPhone 7+ and iPad Mini 2). Both with different printers. Incidentally, the error also happens when I share the briefing pack as PDF on iOS devices. So I am nearly sure that the problem is not with the hosts or the printers / printer drivers, but with SkyDemon itself. I use the app on all devices in the latest version 3.12.4. It would be very important if this problem is solved as soon as possible because the issue has a legal meaning last: I use the printed map as a security backup when flying and I do not want to be prosecuted because "I had used insufficient materials for flight preparation" if it comes to an accident or something else. Best regards! Peter
By Tim Dawson - 4/23/2019 10:17:03 AM
We are aware that the actual scale can differ slightly to what is written on printed output. However, this is of little importance in practice, as Graham says, and while it will be addressed in due course, I'm afraid it is very low on our development list.
