+xIt's for others to weigh in on most of these suggestions.
What I will say however, is that SkyDemon "truly replaces paper charts" by NOT including every single detail in our maps, but making many a finger-touch away. That is one of many things that makes it better than static charts. It sounds like you're new to SkyDemon, and perhaps some things are yet to be discovered.
I realise that, maybe I went a bit too far with that statement.
The point about the FIS boundaries is not knowing where to use that single finger-touch. Showing the boundaries of FIS would allow you to at least see where to tap to check the frequency. Right now, flying across FIS boundaries I find myself randomly tapping places on the map to figure out when exactly I should switch (or take out a paper chart and check the boundary on there).
All other points (except for maybe the last one) are more of the "on-touch-away information" type. The most important ones to me being the course instrument and frequency listing order. The others are more minor things, the others are, again, just ideas I had.
I'm (relatively) new to the forums, as in I don't use them often, but I've been using SD for the past 4 years.
