If it hears the transmissions from the aircraft itself, it will know the barometric altitude of the aircraft and should be compatible with SkyDemon. If it isn't sending that data, then we can't help.
Other products may happily present you with other traffic, giving you the impression that you are being protected from it, when you are not. That's dangerous, and is not the way we operate.
