+xI have yet to get traffic to display in SD. I have a TRX1500A connected to an AIR Connect with wi-fi and have tried FLARM and SkyEcho options in SD. No location data is received from either option. Also SD asks for an AIR Connect PIN, preset to 1234. The latest AIR Connect as fitted does not need a PIN.
Any advice?
please enter a PIN code higher than 5500, for example, 5555. Currently, the PIN code sets up the IP address in SD, therefore, it will only connect if having entered the correct one (even if the new AIR Connect normally does not need a PIN code anymore).
Please contact us if you experience issues.
Best regards
Marc Förderer
AIR Avionics
