By eundfv - 6/22/2018 10:26:26 AM
Hi Folks,
i would like to plan a flight to Italy with a microlight. What i miss is the small microlight fields, that are not listed in the official maps (physical ICAO map). e.g. Termon close to Bolzano. Any ideas how to get it in for flight planning to SkyDemon?
Thanks a lot & best regards fritz
By Tim Dawson - 6/25/2018 9:16:31 AM
The example you gave, Termon, is present in SkyDemon and visible by default. As are most if not all microlight sites in Italy. Are you sure someone hasn't turned them off in your map settings?
