By chrisn - 6/13/2018 1:09:37 PM
I noticed that in Bern (LSZB) the ICAO map has two transit-routes (north and sound). It doesn't look like these are in the normal SD layer, so I thought I'd add them as waypoints (which is easy, because I can make the "Area chart" appear and plot them at the right point.
However, if I then remove the area chart overlay again, my points are very hidden.. Would be cool if I could make a line between points as well. Or should I suggest that you add these transit routes as vfr-routes?
Also, can my custom waypoints be laid on top of the area-chart overlay somehow? Now they disappear, I may have missed an option.
By Tim Dawson - 6/21/2018 9:24:49 AM
Most map artefacts including waypoints are hidden by the overlay of a plate, this is deliberate. You can define your own airways/routes using the Data Creator tool on PC but these would also be hidden if the plate was overlaid. I believe we have discussed adding these specific routes into SkyDemon before, but Skyguide will not publish official coordinates for them.
