By Betrn - 3/4/2018 10:36:23 AM
Hello, I have a question regarding the date/time range used for NOTAM selection. It seems that, by default, it’s about 1.5 day, from “now”. It means that on the map, some useless NOTAMs for the navigation I’m planning to do are displayed. In order to avoid to have a map overloaded by these NOTAMs, I have to modify the validity date range before each flight. Is there a way to simply get NOTAMs valid for the planned flight duration (with a small security)? Thanks in advance for your help. Regards, Thierry
By Tim Dawson - 3/12/2018 10:42:11 AM
Not really, because when you haven't set your takeoff time, SkyDemon assumes you're about to take off for the purposes of many items in the briefing. It can't be sure of that though, so NOTAM for the current day and the next day are displayed.
