By drnicolas - 3/3/2018 6:04:00 PM
The latest Update is another pretty good step forward for everybody IFR-flying. After using it on 2 simulated IFR filights and 1 real-life, I see more wishes.
1. Optimize the direct-to dialog. At the moment: Tap the blue button - Tap direct to - Tap search(right upper corner) - then search for a direct-to item. That should be shorter. I would love to see a separate direct-to-button, with the cursor placed right in a text-input-box after pressing it. The list of nearby items is perfect and should stay as it is.
2. a quick way of changing between track-up map and full-screen presentation of the approach-chart and back.
Thank you for your work!
