By Mach2 - 2/20/2018 5:45:32 PM
is it possible to create several profiles for the same aircraft type? We have 3 T67M aircraft that have completely different weights, fuel loads etc but I don't seem to be able to open a second profile to create one for each. Thanks, John
By Tim Dawson - 2/21/2018 5:24:59 PM
This is a good point, and something we need to fix. In the meantime you can use the registration trick as posted above (not desirable really) or change the filename on disk by physically copying the aircraft profile (only easy on PC).
