By ArnaudC - 2/20/2018 10:45:54 AM
Running SD 3.9.1 on Windows. On the top right panel with W&B, it used to be that if you put fuel to more than max available, it would auto adjust it back to max as specified in the aircraft profile. I quite liked it, so I don't have to remember if this particular plane has 48 or 77 or 94 gallons (and all the variants in between), I put it once in the aircraft profile and am done with it. This feature was there until a few versions ago. Now I can flight plan my PA-28 with 1000 liters onboard fuel. The weight and CoG crosses just disappear off the chart.
The flight details at the bottom right has a slider that does still stop at the max fuel.
Can we get back the auto-adjust to max fuel when overfilling in the W&B panel?
By ArnaudC - 2/21/2018 1:12:10 PM
Done.
