Tim, Thanks for the latest version (.9.13) My observations before the big decision "To Buy or Not to Buy":
Running on a Navigo 4.3" PNA (Win CE 5.0), if connected to the PC (via Activesync), SkyDemon Inflight starts up without the Map showing.
Only happened on versions .9.12 & .9.13. Disconnecting & restarting the Navigo allows SkyDemon Inflight to function normally.
The "Map Font Size" option has no effect on the Navigo. Could it be looking for a font we don't have?
Will there be further updating of the the Map?
In the south (Shoreham in particular), we are suffering a discrepancy with the UK Map & Roads & Railways overlay.
Everything seems to be up to 1/2 mile out. Are they a different "projection" to the Aviation Database ? (which is spot on).
Obvious points of reference are:
The VRPs at "Washington Intersection" & "Lewis Intersection", neither corresponding road is under the VRP. (The VRP is correct)
The Railway does not run through the runways at Shoreham. (& certainly not North of the NDB)
Only small points, I know but they just detract from an otherwise excellent piece of software.
Hope I don't sound too "nitpicking"
, and on an upbeat note, the new SkyDemon icon looks good on the Navigo Menu.
Regards,
Max.
P.S. Still can't get the line spacing right?
