+xThanks for the reply, but there's no option under the gear to download high-def terrain for me. Maybe that option disappears when you download the data? I'm not sure, maybe I already downloaded it sometime?
i have just looked for your problem in the SkyDemon pdf-Manual available in the web. There the manual says (page 15):
If you don’t see the ‘Download High-Res terrain option, it means high-resolution terrain data is already downloaded in the area you’re looking at.
So, as you mentioned, that describes the unavailable button on your device pretty well :-)
Greetings from Austria
Daniel
