Airspace C not shown in graphical Stack on PC 3.8.1
http://forums.skydemon.aero/Topic23328.aspx
By derWessi - 5/19/2017 8:01:22 AM
Good Morning SD Team,
I'm just discovering the new fancy graphical airspace stack in the what's here window and I think I might have found a bug.
I‌ attached an image that shows the graphical stack in the vicinity of Berlin. As you can see the airspace C is not displayed in the vertical stack. On my android device it is shown properly from FL65-FL660.
Regards,
Andreas‌‌
By publicom - 5/18/2022 1:36:46 PM
Tim Dawson - 5/18/2022 1:30:18 PM
Your question has already been answered. The height of the stack is determined by how much stuff is showing in the list on the right, so if it happens to be tall enough, you'll see high airspace depicted even if it's not showing on the map.
The Mapping options in our iOS app are available at the bottom-right corner of the map.
Yes. You see: It's no problem to have a huge Window, if there is a big amount of textual information.
So it should be no problem, to make the window slightly bigger, to reliable show the airspaces even when less textual information is available.
