Hello,I could not locate the TSAs in Belgium neither on the map nor in the en-route window (profile of the flight). These are used by military and are triggered by NOTAMs. Usually, they are from 4500MSL up. On the other hand, the Danger areas (usually up to 4500MSL) are correctly depicted.
I checked the clipping setting and it was OK (e.g. up to 6000 feet).
Is that OK?
Thank you.
Milan
