By jfw - 5/9/2017 10:07:01 AM
Hello, I know that you can change the unit preference for SD but I would suggest to also add unit preference for the aircraft details (eg W&B). Renting Cessna & Robin, I have to switch around when completing the aircraft profiles & W&B. I think it would be easier to crosscheck that everything is correct is you could determine which unit to use per aircraft.
Any comments & views are welocome.
Br J
By SonntagChr - 5/27/2018 3:24:59 PM
Hi, i'm quite new with SD , a great program, but with the units i'm not that happy.
Flying a Robin DR253 the most units in km/h m/s etc... and a AQUILA At01 ther the units are mph / ft/ etc... But I would prefere the distances in the pilot log in miles , becouse it's the usulay uses unit.
Make a split between the speed and the distance units
and it would be grate to intigrat this in the aerplane profile , to have the same untis as in the instruments (groundspeed ets)
Best regards
Christian
