By Giuan - 4/11/2017 9:06:23 PM
When it will be operative? This feature that could cross informations as wind, controlled areas, danger reatricted and prohibited areas should help flyers on choosing the best solution. I think that including options as "would you like to fly in uncontrolled airspaces, at which level flight? Controlled areas but at a certain flight level? At a certain level, crossing controlled areas? And, for the future, even IFR autorouting. I'm a satisfied customer but this will decrease the distance between our software and Garmin Pilot. Then, if will ibe possible to have a feature to download theflight plan to Garmin avionics or Flighstream 110/210.
By Tim Dawson - 4/13/2017 4:21:49 PM
VFR and IFR autorouting is very different.
We currently have no plans to incorporate IFR autorouting into SkyDemon. There is an excellent free solution at autorouter.eu which will perform this function and is compatible with SkyDemon. Once your route is generated, accepted and filed in that solution, you can press a button to have it open in SkyDemon ready for navigation.
VFR autorouting is a strange option that I understand some software offers, whereby the software will decide where you're going with reference to controlled airspace, dangerous airspace and other hazards. In our opinion if a piece of software does that for you, you haven't actually planned your flight at all. We regard it as dangerous and will not be adopting it in SkyDemon.
