By Furio - 2/27/2017 5:09:39 PM
If I save a route with an aircraft using NM and then I save the same route with another aircraft usìng SM (with different file name of course), SkyDemon memorize the last unit entered (either SM or NM). In fact when I open the two routes I'm supposing to find the two routes withthe two different aircraft as saved with the two different units as set-up for each single aircraft ... is not the case .. Am I wrong? HELP .. thanks in advance. Furio
By Tim Dawson - 2/28/2017 11:31:14 AM
Your choice of preferred units of measurement has nothing to do with a particular aircraft profile. It is a user preference.
