By Hetzenauer - 3/30/2017 10:12:38 AM
😳 That was really fast- thank you very much!!
By Oliver Voigt - 3/30/2017 8:15:44 PM
Still very happy about these excellent fast reaction! An absolute well done job and great thanks to you and your team!!
Best greeting and all the best for your presence at the Aero in Friedrichshafen!
Maybe meet us!
Oliver
By Hacho - 5/20/2017 5:07:59 AM
The Plogs just shows the Monitor Frequency but not the squawk.
By Oliver Voigt - 2/3/2017 10:37:01 PM
The new season begins with a change of procedures in TMZ (Transponder Mandandory Zone) areas. According to the previous regulation, a transponder had to be carried along and coded on code 7000.
A new addition is the radio readiness on radio. According to information from the Federal Committee on Lower Airspace (BAUL) this radio capability is to be signaled with a corresponding Squawk code. These will be published in the DFS ICAO aeronautical charts available from March. The expansions of the individual TMZs remain unchanged.
In practice, this does not mean the release of the corresponding transponder code and monitoring on the published "Listening Squawk" frequency. It is hoped that this will improve the safety of the air because, in case of doubt, a pilot can quickly make contact with the pilot. There were also problems in the past that the Squawk codes were still "tagged" for several days, because after logging out of FIS no code 7000 was saved and / or the following pilots did not check your transponders.
How SD will handle these Thematik? ..as like the FIS Frequency in the terrain-data?
By Tim Dawson - 5/25/2017 1:46:26 AM
They show both, Hacho. Please ensure you're using the latest version of SkyDemon. If you are, please provide a screenshot and sample route so we can look into it for you. Thanks!
By Hacho - 5/25/2017 2:29:38 PM
+xThey show both, Hacho. Please ensure you're using the latest version of SkyDemon. If you are, please provide a screenshot and sample route so we can look into it for you. Thanks!
Ok thanks, after the update it works!
