Internal pressure sensor iPad / iPhone for a more accuracte altitude
http://forums.skydemon.aero/Topic20998.aspx
By OSiRS - 12/10/2016 10:45:20 AM
Hi Sky Demon Team,
Did you thought about to use the internal pressure sensor to calculate a more accurate altitude / height based on the QNH of the nearest airfield (if available via LTE, 3G) and the actual pressure on the flight level? I found this feature in a different software and think that it could be a benefit for SD.
Many thanks!
Greetings from Germany,
Olaf!
