By Julian - 10/11/2016 12:25:40 PM
Hi, What am I missing! Most of my flying is local flights so on the IPad I just create a route from an airfield and set a Fly within radius. It appears that NOTAM'd areas in that radius don't appear but if I set a take off and landing airfield in the same area they do. Thanks, Julian
By Sky Painter - 10/11/2016 1:20:09 PM
+xHi, What am I missing! Most of my flying is local flights so on the IPad I just create a route from an airfield and set a Fly within radius. It appears that NOTAM'd areas in that radius don't appear but if I set a take off and landing airfield in the same area they do. Thanks, Julian Hi Julian
You don't have to create a route. All you have to do is:- Tap the NOTAM tab, then tap on Tools > Area Brief, set the desired radius of your local flying area, then tap anywhere on the chart to close the NOTAM pop-up and you will see NOTAM displayed for your selected local flying area.
