Suggestion - Overhaul an dupdate the Settings menu?
http://forums.skydemon.aero/Topic20245.aspx
By tnowak - 9/19/2016 11:05:24 AM
As SD adds more features I find I can't quite remember where to go to check or change a setting, especially if I am at an airfield and my SD manual at home.
Would it be a good idea to simplify and standardize ALL the settings and configurable items using a simplified menu and sub-menu structure?
At the moment the option to change settings are under many different parts of the SD application.
Perhaps change SD so ALL setting are only available/accessed by touching the "gear" (settings) icon?
A settings change top level menu structure something like this?:
My Charts
My Aircraft
My Mapping
My Planning Settings
My Navigation Settings
My FPL Settings
My Connectivity Settings
etc.
It would also be helpful to be able to see a list of my device's setup/setting so I could print them for reference purposes?
Perhaps a file (called my device setup.txt ?) could be uploaded to the SD cloud.
Tony
