SIMULATION
http://forums.skydemon.aero/Topic20112.aspx
By cocoroman - 9/13/2016 5:26:17 PM
Hi, my Home Airfield is LSGN (Swiss), why each time when I start to Simulate. It will straight go to England, then I have to pull my Plane back to LSGN. Kind of pain I think. Don't want to think if my Home Airfield was, Auckland.
Cheers to all.
By cocoroman - 9/14/2016 12:01:06 PM
Sky Painter - 9/14/2016 4:07:19 AM
cocoroman - 9/13/2016 9:15:13 PM
Sky Painter - 9/13/2016 7:36:59 PM
Cheers to all.
Cheers to all.
If you do not create a route first, Simulate will always default to a flight in progress in south west England.
Hi Mike, sure as I have written before, I have set my Home Airfield, I don't need to plan a Route on SD, even if you are flying Local, like 50 miles of radial. As far as you are starting Simulating, it will bring you to South of England..
Whether or not you have set your home airfield makes no difference, but you must create a route from A to B first. It's not enough to just tell SD that your flying locally within 50 miles radius. Then when you start the simulation, the little yellow aircraft will start to fly the route that you have created.
O.K. got it, thanks for the info.
