NOTAMs on iOS devices
http://forums.skydemon.aero/Topic19597.aspx
By TheHoff - 8/7/2016 8:21:30 AM
Although NOTAMS are listed under the NOTAM tab, they are not showing on the map. Problem on iPhone 6 and iPad2.
By TheHoff - 8/7/2016 9:28:12 AM
Shifu - 8/7/2016 9:25:08 AM
No Problem here (iP6, iPP). Did you "unhide hidden NOTAMs" (NOTAM tab - Tools) and checked the filter under "advanced"? What happens if you touch the glasses symbol of a NOTAM in the tab? I don't know whether this was always the case, but now obstacles NOTAMs are depicted by small purple symbols only.
Fixed now. The view was off. The strange thing is it was on all devices and there is no way I switched of the NOTAM view on them all. I may have done one by mistake. I wonder if they sync?
Resolution if anyone else get same prob:
- tap the map icon (bottom left next to the north up icon.)
- select airspace form the menu.
- the first item is NOTAM, toggle it on.
