French low level military zones missing.
http://forums.skydemon.aero/Topic19422.aspx
By pgroell - 7/26/2016 4:54:12 PM
it might be me but I am missing some low level military zones in France.
There are some areas where two zones are on top of each other :
- one from SFC to 800 ASFC
- one from 800 ASFC to anything higher.
The lower level is not always activated at the same time as the higner level and is missing on my charts.
Here some explanations on the official low level chart  (look for example the most eastern blue zone R45D is lower level, R45S7 is upper level).
https://www.sia.aviation-civile.gouv.fr/dossier/3rdparty/CARTE_RTBA_0116.pdf
For tomorrow, both R45D and R45S7 are activated see the dark red on the map for tomorrow.
I think all the blue zones on the link above are missing.
Pascal
By pgroell - 7/29/2016 3:56:32 PM
Tim Dawson - 7/27/2016 9:15:23 AM
We have R45D and R45S7 in SkyDemon. In fact we should have all French LFR areas in SkyDemon as long as they're below FL195. You can even search for them using the Find tool, type in their full name e.g. LFR45D.
If you still believe some areas are missing, please give us their names.
Thanks for your answer, it fact the problem was me. I had an initial planned route going through R45D but I later changed it and then only checked the virtual radar still thinking I was going through R45D. After your answer I checked again and everything is indeed plotted. Sorry for your time.
Pascal
