By kestrel539 - 7/24/2016 1:44:13 PM
Been happily running SD on Win 7 desktop pc for a few years. By mistake, I minimised the window, and the programme has vanished from the desktop. It still shows as running on the task bar, but I am unable to see it, and maximise the window. Anybody else had this problem, and found a way out of it? Cheers Ian K
By JoFe - 1/6/2018 8:45:53 PM
+x+x+xBeen happily running SD on Win 7 desktop pc for a few years. By mistake, I minimised the window, and the programme has vanished from the desktop. It still shows as running on the task bar, but I am unable to see it, and maximise the window. Anybody else had this problem, and found a way out of it? Cheers Ian K Have you tried the standard Microsoft fix? Shut down and reboot? Do you still see the problem? Tony Nowak Oh yes, also tried deleting Skydemon, reg-hacking to remove every trace of it, then re-installing. None of that worked. However, last night, found another site that suggested the widow key and up arrow on the keyboard.............that worked. Just got to work out now why it happened in the first place. An old thread but still a very useful answer! Many thanks, kestrel, Window key and up arrow did the trick.
John
