Tapping location report - loses Track Radial
http://forums.skydemon.aero/Topic19108.aspx
By Fleagle - 6/13/2016 2:17:17 PM
When you have set up a track radial from a given point, if you tap the location report to either see your plog or the position in relation to next waypoint, why does the radial you have just set up get deleted from your screen ? If you wanted/ needed it, you have to set up up again.
Curiously selecting plog via the sky demon logo / menu - doesn't wipe out the radial.
By Tim Dawson - 6/14/2016 3:03:03 PM
Tapping the instrument which displays the waypoint you're tracking is the way to cancel the tracking of the waypoint. That is how it's designed to work.
