Import of a profile
http://forums.skydemon.aero/Topic19080.aspx
By piermauro - 6/5/2017 11:54:19 AM
Sky Painter - 6/7/2016 7:00:05 AM
Copy the aircraft profile file to .../My Documents/Skydemon/Aircraft on your PC. To save it to the cloud, launch SD on your PC, click on the Aircraft icon, select the aircraft profile, then click on Save to Cloud. To download it to your tablet or phone, go to Settings/Aircraft, tap on the Cloud button, then tap on the Open from Cloud button, tap the required aircraft profile and you're done.
SD do not provide aircraft profiles. It is up to users to create their own aircraft profiles which are often shared via these forums.
Hope that helps.
I am looking for a profile for Helicopter Bell 206 Ranger III. Did anyone posted it?
By t.gerlach - 6/6/2016 8:45:35 PM
As I am new at SkyDemon a probably simple question:
If someone provides n aircraft profile, how can I mkae use of it in my SkyDemon?
I do not find an "import function"?
How would I get it into my cloud?
Why does not SD offer an Aquila 210 as an official profile (no warranty would be ok)
It is such a well known plane and so often used in Flightschools in Germany.
If I want to setup W/B I constantly fail and cannot find the cause. :-(
Thomas
