latest version print centre
http://forums.skydemon.aero/Topic18947.aspx
By poorterp - 5/22/2016 1:55:47 PM
Hi Skydemon team,
in the latest version of skydemon 3.6.0.0 you have included the time, distance and heading for each leg on the printout
this is a nice feature but it would be even more better if we could select in the enroute chart settings to put this
on/off. The reason id that i print sometimes the enroute charts in advance to study it and to add lots of info
to them. However, at time of printing i dont have the right values of the wind yet .. and then the info given is misleading.
So, being able to select it on or off would be very helpfull.
Also it would be helpfull if we could have a selection to have detailed or summarized enroute charts at print time.
Lately the printed charts contain less info ...
PROBLEM : I noticed that if I go several times into print centre and back that the amount of detail varies a lot
                   sometimes i loose on some pages of the route a lot of roads or waterways...
for example : i am currently preparing a flight from EBUL to EDBM (310 nm) and when I printed the first time i had lots of details on the
                   first page around flanders with all roads etc.. but around hildesheim in Germany i had only the contours of the ground,
                   all roads were gone. So I went out of the print centre and started again. And then i had suddenly no more roads and features
                   in belgium but more features and roads in the hildesheim area ...
                   I could not find a consistent behaviour
Thanks a lot...
By poorterp - 6/2/2016 8:20:55 PM
thanks for the respons but could you make the extra info on the leg switchable with a flag so i can print without the info or with the info
so when we do the preparation of a flight some days in advance we can already print without disturbing info which is not accurate yet.
thanks a lot
