Odd glide safe behaviour
http://forums.skydemon.aero/Topic18928.aspx
By rikur - 5/18/2016 9:17:08 PM
Not sure if it's a bug / quirk / other ....
On my last flight glide-safe appeared several times when I wasn't over water .... not so much as a garden pond, and at least 4 miles from the coast.  It behaved correctly when I was over water, but had additional spurious appearances.
Not a major problem, just mentioning it.
Edit:  Thinking about it, I may have been above terrain that is below sea level (Lincolnshire) at the time if that's relevant.
Android - latest version of everything.
By Tim Dawson - 5/19/2016 2:46:56 PM
It uses the terrain height to quickly determine whether you're over water or not. So terrain height of <= 0 would cause it to appear.
