deleting routes
http://forums.skydemon.aero/Topic1866.aspx
By pink leader - 2/6/2011 1:27:09 PM
I wd like to suggest an improvement re managing routes.
At present when in PC or Mobile (from within programme), its necessary to delete "old" routes individually  .. not only that you have to do it on both or they will reappear!
I wd like to ask for ability to select a number at a time on the PC and a "delete all" function on the mobile (ones you want to keep on the PC will come back again at next sync).
Its easy to get very cluttered up!!
D
By Tim Dawson - 2/8/2011 11:38:23 AM
We arrived at the current naming of exported routes after quite a lot of feedback from Garmin users. We can't just switch to using the filename, partly because we're quite happy with the current system (implemented due to feedback) and partly because there may well not even be a filename, if the route isn't saved.
I really like the idea of having an option to export a single route to a connected SkyDemon Mobile device.
