Close traffic symbols
http://forums.skydemon.aero/Topic18239.aspx
By Birdyboy - 2/28/2016 9:40:45 AM
I've not flown a lot recently due to weather, I have Mode S and PLARM but don't recall seeing green circles around the plane (OK described in manual as close traffic no bearing) but I have recently seen:
a) a red dot on the plane
b) one white circle around it
c) two white circles
Note; no traffic observed in any of these cases - but doesn't mean it wasn't there!
Can't find any info on these in the literature.
Do I gather that I could now take an audio feed from SD for alerts and connect to my Radio Aux In ? That would be good (even if I did just spend 99E on an audio alarm license from PFLARM last week!
By Tim Dawson - 2/29/2016 12:44:36 PM
Bearingless targets are shown as a circle around your aircraft. They're coloured white, green or red the same as other traffic targets, based purely on what Flarm tells us to do. It simply gives us a range (which is mostly made up and not reliable) and an "alert level".
You may well be able to connect your tablet to your intercom system as a way of getting alert sounds into it.
