Select aircraft for new route
http://forums.skydemon.aero/Topic1687.aspx
By derekf - 1/17/2011 6:45:58 PM
Hiya,
Would it be possible when clicking on New Route to display the current aircraft in use and allow selection of a different one in the same window you enter departure/destination etc.
Would make it much quicker when you fly different a/c than having to go to aircraft and select one to use first.
Thanks,
Derek...
By Tim Dawson - 1/21/2011 12:36:20 PM
I'm not sure how it is "buried" as that window is, by default, always visible at the bottom right. If you wish to move the window or merge it with others you can click on its tab or titlebar and drag it to other locations onscreen using the guides that appear.
