Removing an airfield waypoint
http://forums.skydemon.aero/Topic16805.aspx
By PeterGristwood - 8/19/2015 11:18:53 PM
I've received the latest update and bug fix, but I've only just noticed an issue I've not seen before on the Nexus 7
If you plan a route with a number or waypoints then decide to remove one, normally you press and hold the waypoint until the dialog box appears with 'Remove Waypoint' in the corner and press that to remove it.
When the waypoint happens to be an airfield, when you press and hold the waypoint, the dialog box appears as above, but it is impossible to do anything as the airfield dialog box then appears.
The only way to delete the waypont, as far as I can see, is to drag it away from the airfield then press and hold to get the waypoint dialog.
Is this working as designed?
By InfrequentFlyer - 8/20/2015 8:42:04 AM
Touch and hold the airfield waypoint as before, then the usual "What's here" dialog appears, but if you're at an airfield this dialog is immediately replaced by the airfield information.  Touch the "back" key, and it goes back to the "What's here" dialog, including the "Remove Waypoint" button.
There was a post a week or so ago about this, and Tim said that it's as designed, as most of the time you want the airfield information dialog, and can easily go back to the "What's here" dialog.
