By InfrequentFlyer - 8/15/2015 10:36:40 PM
Today when I tried to download a plate, Skydemon (PC, v3.4.0.5 on W7 64-bit) hangs when downloading the plate. The "Downloading plate" window appears, but it loops continuosly downloading the plate again and again:
The only way I can stop the infinite loop is to try to kill the little window if I'm fast enough clicking the close button, or to disable the network (or kill SkyDemon).
Having killed the downloading window, it appears that the plate has downloaded OK, so it appears green in the plate list, and if I try to open it, it doesn't try to download it again. But any time I try to open a plate that hasn't previously been downloaded, it loops forever, apparently downloading the plate over and over again.
I tried removing SkyDemon, all user data from C:\Users\<username>\Documents\SkyDemon and plates from C:\Users\<username>\AppData\Roaming\Divelements Limited and reloading SkyDemon 3.4.0 and the problem persists - infinite looping whenever it downloads a plate.
I then reloaded v3.3.2 (without deleting any user data) and it works fine. The Android version of 3.4 also works fine for me.
A problem with the PC version of 3.4, or am I doing something wrong?
By InfrequentFlyer - 8/19/2015 5:04:03 PM
And thanks for getting out the new release verson 3.4.1 (which fixes the problem) so quickly!
