Map ruler labeling
http://forums.skydemon.aero/Topic16728.aspx
By kobaje - 8/14/2015 10:07:59 AM
I appreciate the ruler function but there is one thing you should change:
The labeling of the ruler is only well readable in one direction. The labeling for the other direction is upside-down (see picture). That shouldn't be much work to change and would approve readability. Thanks
Cheers
Jens
By Tim Dawson - 8/19/2015 9:55:40 AM
At the moment the text orientation is by design, as it incorporates the arrows that show which direction the text applies to. If both directions are the correct way up for easy reading I think it reduces the instant appreciation of which piece of text refers to which direction.
